It is currently Sat Jul 19, 2025 6:22 pm
PostPosted: Sat Dec 02, 2006 12:43 pm
First name: Jim
Last Name: Kirby
I was speculating that my bandsaw tension spring had died here recently (Delta 14"), and after some reinforcing backup from Todd Stock, I got a replacement Carter spring from Woodcraft. Has anyone had a problem with these springs being too short? The spring doesn't take up tension until the tension indicator is already up past the 1/8" mark.
This doesn't mean that the spring isn't able to eventually tension the blade, but it sure is out of calibration with the tension marks on the machine. jtkirby39053.8637731482
Jim Kirby
kirby@udel.edu
PostPosted: Sat Dec 02, 2006 1:47 pm
First name: Jim
Last Name: Kirby
Todd - Thanks for that clue, that makes sense.
JK
Jim Kirby
kirby@udel.edu
PostPosted: Sun Dec 03, 2006 2:51 am
Jim, I was recently looking for guide bearings for my Rockwell 10". There is a website that is usually called "Servicenet" by woodworkers (link) that has parts for the most popular tool brands. I posted my question about servicenet to a woodworking forum here
and got some good responses about servicenet. I plan on ordering soon.
Oh and BTW they have manuals as well.nathan c39054.4527430556
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Sun Dec 03, 2006 5:05 am
Todd...I have some questions about a used 14" Delta (with riser block) that I bought some months ago.
The tension indicator (red mark) is not visible and I've been tensioning by feel... once the blade produces a ringing tone when snapped, I stop tightening. I know that this could be problematic and wanted to get some advice.
Where "should" the red mark be located? Right now, the 1/8" mark aligns about midway along height of the nut at the bottom of the yellow spring. This is with a 1/2" wide x .023" kerf blade. I'd be surprised if I stumbled at the proper tension but wanted to get your expert opinions and guidance. TIA.
PostPosted: Mon Dec 04, 2006 3:48 am
Newbie question. What exactly does "resaw" mean? What about barrelling?
PostPosted: Mon Dec 04, 2006 5:04 am
Thanks, Todd. Great info! Just what I needed.
PostPosted: Mon Dec 04, 2006 6:19 am
Todd
Any experience or opinions on the larger Grizzly bandsaws in the 18 or 20 inch range. I'm looking to replace my worn out 14" import with something a little more heavy duty to do some resaw work.
Bob
PostPosted: Mon Dec 04, 2006 7:16 am
[QUOTE=ToddStock] Good questions...
Resawing is just that - taking a relatively thick board and cutting it into thinner slices. Imagine the wood is 36" long, 8" wide, and 3/4" thick. With careful sawing, we can get four pieces that are still 36" x 8", but now each piece is only .130-.140 or so thick... perfect to use for backs and sides after a bit of sanding or planing. In the pic below, each larger piece of stock is cut into these thinner pieces - a board that started out 12' long x 10" wide x 5/4 thick wound up yielding 12 side sets and 9 back sets - about $15/set for some lightly figured bubinga from a local Woodraft.
Barrelling occurs when resawing with a blade that is not properly tracked or tensioned...the blade describes a curved path down through the wood that can look a bit like the shape of a barrel. Not good - wastes wood and is tough on the blade as well...tension and proper tracking takes care of the issue.
Thank you.
